jdmser »
https://forums.nicoclub.com/jdmser-u10477.html
Sat Aug 18, 2007 11:52 am
I got the motor up and running in a drivable state. Big thanks to Carl for the tune. First thing I did was take it to have the emissions test done. I really just want to know where I stood with them and it doesn't seem that bad. The requirements are 220 ppm hydrocarbon and I had 680 ppm. At idle the a/f ratio bouces back and forth between 12.5 and 13. Should I lean it out to 14.7, I would think that would be enough? I had no carbonmonoxide and we don't measure for nox where I live. Another something I notice was that the boost seem to come on fairly late, about 4000 and the wastegate opened at 7 psi. I didn't stay in it very long. Only took it up to 6500 rpm or so. Whole time boost stayed and 7 psi and pulled about like the stock turbo. For those of you who don't know, the car was down for a year while it got port and polish, tomie 260 procams, and t3/t04e 50 trim. Can a bigger turbo open a wastgate at a lower psi than a smaller one? With the stock turbo it held boost to around 10 psi.
