I f*&#ed up my transmission......!!!!
74260zt
Car: rb26powered early 74 260z car
Hey guy... chit happens to the best of us.... there ain't a swinging sack here that hasn't goofed up something them self's.... lol
240z4u
Car: '95 Nissan 240SX
Props for admitting your mistake, and life goes on!
Chalk one up to experience.
Evan
meet07
Car: 89 180sx rb25det
Spec is trying to sell me a whole new kit. I think I can do away with just a pressure plate and bearing. The disc still looks new. I mean I drove the car for about 50 miles tops......If they wont sell me a spec pressure plate I think I may go with ACT heavy duty.
240z4u
ACT is very good about selling pieces of kits like that, that heavy duty plate is stiff... be prepared. My leg hurt for about a month before I got used to it in heavy traffic.
Evan
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
I'm impressed you admitted to your mistake! Very well done. Also, i hope you get a good deal on the new clutch. Good luck.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
meet07 wrote:Spec is trying to sell me a whole new kit. I think I can do away with just a pressure plate and bearing. The disc still looks new. I mean I drove the car for about 50 miles tops......If they wont sell me a spec pressure plate I think I may go with ACT heavy duty.
I have a ACT Heavy Duty clutch kit in stock, let me know.
http://shop.rawbrokerage.com/p...d=201
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
damm, bump for admittin ur mistake tho, specs str8 i just gernaded my copmetition clutch, a rivet popped off the pressure plate n it came apart in the bellhousing area, talk about some scary ****, god damm! well keep us posted on whatu end up running, good luck
meet07
yeah im going to pass on the kit raw but im sure ill need one in the future. i had a act on my turbo integra and i loved it. just figured that i would try the act out. im buying an act pressure plate tomm. i need her running by next weekend. thanx guys
meet07
well i put the new release bearing in last nite and the clutch engages like it is suppose to. but i noticed a rattle noise when moving. sounds like it coming from the transmission. i thought it was the exhaust but i only looked at it for 2 minutes in the dark. any input
meet07
Update!!! I jacked the car up to relaize that the noise I was hearing came from a broken stud in between my rotor and dust plate. yaayyy found that problem. I attempted to drive the car last night to work just to make sure everything was ok. Once I got onto the beltline I realized if I press the gas(75% throttle) the clutch would slip like crazy..... So went to work and on the way home I went the the store that sells freaky deaky stuff for me and the misses. Hopped into the car and pressed the clutch..... the clutch pedal would not go down at all. checked my clutch resevoir and it was full. Crawled up under the car to open the bleed valve (maybe there was some trapped air) and nothing came out. Finally pressed the clutch pedal to the floor but this time it would not come back up. Checked the resevoir again and now it was empty.... So I ran to the nearest gas station b/c it was raining, Freaky deaky shop was close and it was 12:00 o'clock....f$#@ came back and put fluid into the resevoir again and pressed the pedal to the floor. Fluid just magically disappeared again. Looked underneath the car to realize that the clutch slave cylinder took a **** on me. So I had to call a tow truck. This car seems to give me bad luck. Not sure if its even worth the headache.....
Should I have went ahead and got the flywheel resurfaced and bought a clutch disc as well or is the fault slave cylinder the problem??? I mean even with the bearing on backwards she grabbed great.
