i dont quite understand what some parts do RPM wise
w1ngzer0
Car: Pfft. i don't own a box
I know depending on the exhaust size you increase top but loose low. Headers do the same or all around for headers? performance cams are usually mid-high. stronger valve springs help response same with lighter flywheel and aluminum drive shaft.
Am i getting these right? if not someone explane please.
gabossie
Car: Your mom
Pretty much correct. Exhaust helps up top because there is less back pressure, but you can loose some torque for the same reason (same thing with headers). Flywheel and driveshaft are simply less rotating mass. When you put power down, less has to be dedicated to spinning these things before it reaches the ground.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
hence makin it easier to rev and plant the power through your rubbers
rebuild your head if you want great rev
but dont take my word for it, thats money
hamsturbation
Car: none yet...
stiffer valve springs
w1ngzer0 wrote: stronger valve springs help response Am i getting these right? if not someone explane please.
stiffer valve springs keep valves from floating at higher RPMS....among other thingsif you want high RPMs, you also want a lighter reciprocating mass, and slower piston speeds helps alot
toki
wait for it.....wait for itt....
OMG SEARCH NUB!!!!~`1``1`1oneonone
drifter_for_life06
Car: Daily: '16 WRX
Exocet
lmao
yea less mas really helps a lot and a redone head helps a whole lot
i made a thread a month or 2 ago about how to get an SR to rev high, search for high revving SR and there was some good info in it
