I dont know where a hose goes
BlockHead
I installed the greddy intake plenum and when I was all said and done I had a coolant hose not hooked up to something, its the one coming off the idle control valve and I was say is about 3/4 inch in diameter. Any help would be appreciative.
BlockHead
Does anyone even know what I am talking about, its the big one that comes off the AAC
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
Can you take a picture of it? I don't know what it is, but I bet we can figure it out if we see a pic.
FAST-DATSUN
Sound like the intake air inlet, but shoot a pic or call us!!!
mambastu
I'd be interested in this too as I'm in exactly the same position at the moment. I presume its this hose you're talking about ?
I'd also be interested to know what connects onto the 4 shiny outlets on the raised boss on the left hand side of the plenum in the picture. The GReddy manual I have is in Japanese and its not much help to be honest.
BlockHead
Mambastu thats the hose I am talking about, thanks for the pic
JonPowell
Car: Cars, Music, My family
That is the hose that goes the the intake piping near the BOV. The brass fitting is the junction between the Valve and the hose off the l shaped intake pipr the goes over the coil packs.
I think that's the one anyway...
JonPowell
Here is a picture of the hose that should connect to the other end of. The end you see here connects to the inlet pipe near where the BOV is bolted on....if I am thinking of the right hose....
FAST-DATSUN
it has to get route back to the intake piping in fornt of the throttle body to allow the AIC/AAC to get air to idle speed. Mack
BlockHead
Thanks guys yall were very helpful, I think I got it, btw if I didnt have that hooked up would it cause it to not want to idle?
JonPowell
Definately, that allow some air to pass when the throttle is closed...without it, you wont get the meter air from the AFM into the engine and the air/fuel ratio will be way off.
Nameless EJ6
Car: What the **** do you think.
And I'm curious.. the extra vacuum ports, are they extra or stock?
jbanach77
Car: family, fast turbo cars
good thread!!!
mambastu
Great, thats one hose found :)
With the vacuum connections on the left hand side...
I presume the far left vaccum connection is for the fuel pressure regulator (?)
Not sure about the next two but presumably a take-off for a boost gauge and another one for the boost solenoid (?)
The far right takeoff is quite large so would this be the connection to the PCV valve in the R/H cam cover (?)
JonPowell
Maybe it's for the brake booster?
mambastu
JonPowell wrote:Maybe it's for the brake booster?
I've narrowed that down to another large bore connection on the top rear Jon :)
JonPowell
Maybe you could post a picture so we could help a little better, I was trying to understand the difference between the far left, far right, and top rear...I misunderstood...sorry. I guess it all depends on where you are standing...
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
LEFT IS DRIVERSIDE, RIGHT IS PASSENGER SIDETOP IS NEAR REAR OF CAR, BOTTOM IS THE FRONT OF CARUPPER IS NEAR HOOD, LOWER IS NEAR GROUND
THIS IS STANDARD MECHANICAL TERMANOLOGY, USED BY EVERY MECHANIC I HAVE EVER WORKED WITH.
JonPowell
I work in a bodyshop, we use that all the time...but I wasnt sure if EVERYONE knows....
mambastu
JonPowell wrote:Maybe you could post a picture so we could help a little better, I was trying to understand the difference between the far left, far right, and top rear...I misunderstood...sorry. I guess it all depends on where you are standing...
Here you go fellas :
http://www.mcse1000.fsnet.co.uk/odd%20hose%202.jpg
JonPowell
Looks like you have figured it out pretty good, the only thing is on mine(all stock) the boost solenoid runs off the intake pipes before the BOV, I am not sure that it will be the same there, it should be though.
Man, I wish I had cash laying around to buy one of those....you lucky bastards!!
I am just jealous, dont mind me.
mambastu
It looks like the standard turbos water return pipe goes into the back of the original plenum. Where have the guys that have fitted the GReddy plenums plumbed it in ?
jbanach77
does anyone have a pic of the manifold installed?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Bump from the dead, I sit and wonder why does it idle on the boost side on not post maf pre turbo?
