I DONT ALWAYS HAVE 5V AT MY MAFS
mummbles20
Car: 1990 nissan 240sx
IF I HOOK UP A METER TO MY MAFS AND KEY THAT CAR ON. I DON`T ALWAYS HAVE A 5V SIGNAL. MY TPS AND THE DISTRIBUTOR ALWAYS HAVE THE 5V SIGNAL. SOMETIMES I ONLY HAVE 2V AND OTHER TIMES ITS 5V. ANYONE HAVE ANY IDEAS
eazye2000
Car: S13 KA-DET
Sounds normal to me. You should only get 5v at the MAF when it's maxed the f*** out.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
You should have 5 volts in at all times, I think. You also have a signal out wire that goes back to the ecu that should read somewhere between .1 and 5 volts depending on the load. Your third wire is the ground. I would check the ground and make sure it has a good connection.
boznuttz
Car: MS13
O RLY? HOW DOES YOUR CAR RUN NOW?
Neejay
boznuttz wrote:O RLY? HOW DOES YOUR CAR RUN NOW?
+1 - IS YOUR CAR RUNNING BAD?
