Canyoncarver »
https://forums.nicoclub.com/canyoncarver-u11755.html
Sun Jul 15, 2007 4:31 pm
First, are you sure it's lifter tick? My injectors make more noise than my lifters. Take a long screwdriver and put it to your ear and then to the injectors and valve covers. You will hear if the noise is coming from the lifters or injectors. Then, check to see if the sound is actually louder at the front of the motor, under the t-belt covers. A ticking noise from there will mean that your vtc springs might need replacing. (this is usually done when the t-belt gets replaced).
Lastly, if the noise is coming from the lifters, it's usually because the lifters are sticking which is caused by oil residue and varnish buildup. One of the old tricks to clean out the engine internals is to run a quart of ATF in the motor for a few minutes before changing the oil. Newer methods include adding Marvel Mystery Oil or Seafoam to the oil to clean things out. These methods are known to reduce the lifter tick in our motors. (it's not a cure-all tho)
