I would like to thank everyone for pointing me in the right direction ESPECIALLY HIJACKER!!! <33
So I spent the whole day cutting up the tray and some other places to run the IC pipe and to plug all the vac lines. Vac lines were plugged following this chart:Basically all lines are routed except one from the EAI control solenoid to the EAI Control valve since I don't have one so that line is plugged.
So basically, my car starts right up now but instead of the smooth vrooom that I'm so used to hearing its now "put put put put put put puttt puttt vrooom" and it idles around 650. It sounds like my brothers half assed subiePlease note that I kept the pedal depressed at all times without letting go and I noticed that it hesitates around 3k then drops to 2.5k and then again at 4. This didn't happen before I plugged in all the "right" lines
I also found this weird looking plug thingie that looked like a mini fuse box of some sort behind the engine. Running from that little box is a plug that connects to itself (wtf?)
Engine has stopped overheating and stays cool around well under half mark.
Just wanted to confirm that what I plugged into was indeed the following:EAI Control SolenoidBoost Pressure SolenoidThese parts were all attached to my starter when my swap came. Right now I have all the lines at the vac lines running back to the passenger side.
I also wanted to know if theres a way to tell if I have DOHC or SOHC lines. The lines inside the car are supposingly DOHC but I'm not sure anymore seeing how the reservior that came with it lined up on the passenger tower and looked the same as my old SOHC one. I dont have the SOHC lines to compare anymore but is there a way I could tell?There is also a plug running from the high pressure line here. It looks exactly the same as the Boost Pressure Solenoid plug But theres a line that I previously noted but I'm not sure if its suppose to plug?
Also, does anyone know if its possible to swap heads with the SR ac hardline and the SOHC ac hardline? (I want to keep the SR pump and just swap the head of the hardline so that I can bolt the sr hardline up instead of having to swap to a KA pump and then custom mounting it in.)
Thanks for all the help!
