I do not know what these wires are going to or coming from
Anthony_dir
Car: 1993 240sx S13 hatch
I was removing the harness and a white and a blue wire were spliced into my ecu connector and they were coming from this black box looking thing and idk what they are and what id need to do with them when I put my sr20 harness through there. I assume they’re important, but I also don’t know so if anybody could tell me what this is thatd be amazing.
elazul
Car: s13
more pics of the box? maybe was run to power a gauge?
Anthony_dir
elazul wrote:
Mon Apr 27, 2020 7:58 am
NukeKS14
Car: '95 Nissan 240SX SE KA24DE-T
AC Cobra Mk IV Rep.
2020 Honda Civic Si
That looks an awful lot like an aftermarket car alarm. What year of s-chassis is this?
From the looks of it 91-94...
Anthony_dir
It’s a 1993 s13 hatch
NukeKS14
AC Cobra Mk IV Rep.
2020 Honda Civic Si
Yeah those aren't standard nissan wiring colors. Are there any labels on the box? Where do the wires go under the dash?
I can see they go under the airbox but... where to?
If they go up under the steering column, i am thinking thats an aftermarket car alarm
Anthony_dir
I’m not sure where they go under the dash. But there’s a line that goes from the top of the box to where the end of the throttle cable goes on the throttle body.
Anthony_dir
I opened the top of the box and it looks like this inside?
NukeKS14
AC Cobra Mk IV Rep.
2020 Honda Civic Si
Oh snap. Someone installed an aftermarket cruise control.
What does your dash look like? Is there a button or switch thats been added for speed control?
If you dont want or need it, you could just remove it altogether. Its aftermarket and not required to go with your swap. Otherwise leave it and i believe the SR has a second pulley on the throttle for ascd. (Automatic speed control device or the oem cruise control)
It works by adjusting your throttle position to keep you at a given speed.
Could be tapping into the harness either for speedo input to its controller or neutral safety switch to tell if the car was shifted out of gear (is it a manual or auto? Mostly likely tapping in for speedo signal i'd wager)
Anthony_dir
Now that you say that there is a spot on the steering wheel where two wires are just coming out of the column. I’m definitely just removing it. I’ll probably just cut the wires and tape them off so I don’t have to remove any more of the dash than I need to. It’s a manual. Thank you so much for your help, I really had no idea what that was lol.
