I don't remember putting that on, but I put rtv around the whole cover, including that spot, has anyone not put that o ring on? I don't think it would leak as long as i had rtv around it.
agreedOM3GA wrote:Just Re-do it. You are talking about a front cover, not the engine internals.
If only I knew this before I had to set my timingHijacker wrote:An easy way to avoid messing up the front section of the head gasket is to not install the oil pump spacer before you put the front cover back on. You'll have to rotate the pump gear around and get it lined up to be able to slide the spacer back in after it's installed though. But it will give you the clearances to get the cover on without screwing the headgasket up.
LOL Probably not now. For some reason, the op seems like the type to ask a question until he hears what he wants to hear, instead of the correct answer.OM3GA wrote:The motors out of the car!?!? do it.
