What is a 2 Watt mega ohm capacitor?
you should have used a resistor. I believe the value is 100k ohm - someone correct me if I'm wrong. I'm sure its low wattage - 1/4 or 1/2 Watt would work fine.
eergsxr wrote:i paid pep boys 40$ to check my codes and it had a knock sensor code, so i did the by pass with a 2 watt mega ohm capacitor and when the car is cold it runs great but when it warms up it gets sluggish again, what could be the problem? is there a way that i can check the codes?
thanx for any help
