I'd appreciate some tips/help
CA18DETBoss
Car: s13 vert vh45de (in progress)
I've got a CA18det in a 1990 240sx hatchback.
Me and my buddies got it running about a month ago and it was fun for a bit...
but....
I want more now.
I want to upgrade to a t28 turbo but I'm not too sure what I'd be getting myself into.
From what I've been able to find I just need to clock the housing on the turbo to make it fit.
But I'm also going to need injectors, fuel pressure regulator..
Not sure what kind of engine management to run either
I just want some help filling in the blanks.
Many thanks,
Dorian
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
engine management you have:
Megasquirt, NIStune, the mods swear by SDS.
you can also just get it chipped (ROM tune?)
i think these injectors are ok:
DSM 450cc, RX7 460cc?, GTR 444cc
Fuel pressure regulator:
Nismo Type A FTW
I'm not sure how far we can go with our MAFS, but you mind as well look into a N60 or N62.
CA18DETBoss
My friend has been talking to the guys at NIStune and it seems to be a really good product so I'm most likely gonna go with that.
as for injectors what would it take to get the DSM injectors to fit?
I don't even know where I would look for GTR injectors lol
sjbsuperman1425
CA18DET
from what I've read, the DSM injectors drop right in, but you need to replace one of the o-rings. Just do a quick google search to be sure.
CA18DETBoss
Ok sweet.
Thanks for the help man.
Oh I wanted to ask about getting a wideband?
pretty much necessary right?
sjbsuperman1425
CA18DET
IMO, i think a wideband should be one of the first things people buy if they have a budget. I'd love to know my a/f ratios all the time, even if it is a stock setup (like mine). Its an absolute for tuning for sure though.
In short, the answer is yes :)
CA18DETBoss
haha alright.
thanks again.
haven't been on the forum for very long but i'm loving it and am glad i registered.
sjbsuperman1425
CA18DET
the CA forum trumps all! Great people in here!
blownhemi
Car: S13 200SX CA18DET HX35
sjbsuperman1425 wrote:engine management you have:
Nismo Type A FTW
E60 MAF (pink label) is more user friendly than the N60 (voltage levels are more similar to stock), and cheaper than the N62, and is supposed to be good out to 350 hp. They are on A32 Maximas, and I think RB25s came with it, too.
CA18DETBoss
Well thanks man that's good to know.
I'll be looking that up.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
the stance turbo clocking kit will save u the headache of clocking it. if u try to rotate the compressor housing itll dump your suction pipe almost into the body and your hot pipe wont want to line up, it kicks things at a fun angle. also get steel braided lines cause the oil feed line can be a bit aggravating when your holding the manifold/turbo assembly and your trying to line up that steel hard line
s13drifter88
the t28 is an excellent turbo if your aiming for the 300 mark, any more and it may begin to choke on the top end. you could have garrett or precision or some (quality) manufacture clip the turbine wheel and then rebalance the unit and u could maybe even have any qualified machine shop port the turbine housing but i wouldnt think that to be ideal for spool characteristics seeing as how that will increase the gap between the vanes and wheel itself. my personal preference is a 2860, slightly larger and almost identical spool characteristics. add an exhaust cam (atleast) to help spool and go with the .86 hotside to keep it from choking at really high rpm and help promote the engines ability to exhale. remember, all that air your shoving in the engine also has to pass through that little hole and around the turbine wheel. the turbo needs to get out what it can take in.
