But there is some noise in the engine, its similiar to ticking!
No, 5W40 will not hurt the car ... as long as it is API certified oil for motor car engine use, you will be perfectly fine. What is "TOTAL" oil - is it a brand name?JDMlove wrote:s***!!! I kept TOTAL SYNTHETIC OIL 9000 which is 5W40!! AND in the manual its written i should put 5W30!!!
Does it make a different!! am i in big troublefeel like crying!!
thanx man, the oil company name (TOTAL)..szh wrote:No, 5W40 will not hurt the car ... as long as it is API certified oil for motor car engine use, you will be perfectly fine. So ... what is "TOTAL" oil?JDMlove wrote:s***!!! I kept TOTAL SYNTHETIC OIL 9000 which is 5W40!! AND in the manual its written i should put 5W30!!!
What do you mean by "kept oil". I am not sure what you are referring to.
How much oil did you put int? You said "the dipstick is covered in oil" - how long do you let the car sit before you check the level?
Let the car sit for a few hours on level ground and check it again - the oil level should be between the low and high marks. If too low, add oil, and if too high, then you need to remove some - perhaps from the drain plug?
Full synthetic will not hurt your engine. I have over 120k miles on my M and it has seen a steady diet of synthetic oil since 10k miles.
If you are truly concerned, have the car taken to a dealer and looked at. Use a flat bed tow (never, ever tow your X model with any set of wheels - front or back - on the ground!) to avoid damaging your transmission.
Z
One of the best oils out there, mang.zerg711 wrote:What the heck is Total? I have never heard of this brand....
TDot wrote:Why are you sitting in the car to hear the ticking. Open the hood, stick your head in, and pin point where you are hearing the sound and report back.....front/back, upper/lower, left/right, by battery, etc. Your descriptions leave no room to attempt to help you.
no, the sound already going on!AND ONCE the fan stars workin i couldn't hear it! then when the fan stopped the sound goneThe00Dustin wrote:He has twice stated that the sounds stops when the fan stops... The fan is electronic, right? So would it be possible to run the fan without the engine to test for the sound and totally isolate this?
