I changed a new injector in my car and my engine blew
redclaw05
Car: 1993 s13 caged vert
So as the story goes. I have been having my car bog when going from 2k-3k rpm.Other then that it drives normal.My friend thought it was Lifters, another thought it was just timing, another the injectors.
First I started by changing the plugs, the wires, distributor rotor and cap.
nothing fixed it.....so i tried the injector. Figured out it was the second injector which is causing the car to crap out.
I have been running on Three Injectors for a week now.
After I install it, I turn on the car.....Knock knock knock. Then my car has gasoline comming out of the exhaust and also i have synthetic oil on the bottom of my car, ***** is toasted.
So i guess I should have just swapped the ***** with an SR20DET. Which I will do next week.
