i cant rev passed 2500 !!!!!!!!!!!!!
oldsoul
Car: cars
i dont know whats wrong. i have a89 240sx sedan, 5speed. its stock. it feels like its hittin a rev limiter at 2500. one day it was fine the next it was not. please gurus i need help. if i cant get to work i cant afford mods!
NISTECH
oldsoul wrote: if i cant get to work i cant afford mods!
Nice reasoning there!!
Check for battery cable fit to battery if its loose or corroded resecure it, if thats ok check the ground lug on the neg cable see if its connected properly to the body of the car and at the engine. if those check ok move to the body grounds for the ecm. In that order. I had a car bite me in the a$$ yesterday that was doing exactly the same thing and i skipped right past the neg battery cable connection points and went right to the grounds under the dash, got a little ahead of myself. the ultimate problem was the body lug on the neg cable was not even bolted to the body . attached it and it was good to go.
oldsoul
Car: cars
ill give that a look, but if anybody have a thought im willin to listen. thanx
C-Kwik
I'd check the MAF connection as well. If you disconnect the MAF, the ECU prevents it from revving past 2500 RPM's as well. Some kind of a safe mode. There may be other reasons the ECU can go into safemode, but I only know of the MAF being one.
dareo
Car: 1993 Q45, 1989 240sx
accordign to my manual a 2500 cut is a malfuntioning MAF, at least the ECU thinks its bad so its shutting you down then.
NISTECH
or loss of ground to maf will have the same effect. do the full maf check on all three lines in particular the ground circuit. with it hooked up and running you should have no more then .02v drop between the maf ground and the intake manifold surface
oldsoul
Car: cars
i did just find a hole in the bendable part of the intake. im goin to the u pull it in the morning, but if i cant find a used one will a ka24de aftermarket intake tube (e.i. ebay) work on my ka24e?
