i cannot find my timing indicator on ka24de
jrsink
i need to locate tdcthe cams are off i need to finish a head gasket install jobi need to find tdc firstplease help!
jrsink
i found the notches for timing on the pulleybut
wellmy problem was multi facetedfirstwe didnt set tdc before taking the cams off and upper timing chain offwe installed the new head gasketbolted the head downand i could not see the timing notches on the timing pulley
we found them eventuallyand had lots of fun manually trying to set tdc by cranking the starter a million times untilwe could get it to line up
right now it is at 10 btdc i thinkthere are 5 notches on the pulleyi think these are 0, 5, 10, 15, 20i have it right on 10
we also measured the stroke out with a tape measureit was almost dead on what seems to be 3.75 (should be 3.78 for stroke)
im having a slight proble now just finishingi need to get the upper timing chain bck on and get the cams bolted in where they need to be
im going to try to bolt the cams down firsttake the sprockets of the cams (maaybe?) or just unbolt the timing chain tensioner pulley under the two camsnot sure
can anyone help
ill post some photos so u can see where im at....
mr_wizard
I don't think anyone is sure what your asking. Alot of what you wrote was hard to understand...
