Robb555 wrote: ↑Mon Dec 20, 2021 8:48 pm
... fit perfect, although in only two positions. I would have to take the bearings off and rotate 180 degrees for them to fit back on. My reasoning for thinking the spindle is oblong.
When I last repacked my front bearings, I had a minor defect on my passenger side shaft that presented itself like this when I reinstalled the bearing. Wear defects like this may not be visually obvious unless the bearing spun on the shaft and created an noticeable mark. The fix for this can be quite simple using a precision flat-stone or a jeweler's file. I used the file on mine to lightly glide over the surface of the shaft until I noticed it catching on a high spot. This type of wear defect is often an area of shaft material displacement, causing a raised spot, which can be filed down very easily as it is typically only a few tenths of one thousandth of an inch, unless of course the bearing has spun and more filing is needed. In all cases, you only need to remove the high spots. Visible low spot scratches should be left alone. Those marks are from where the shaft material was displaced. The high spots will be at the edges of the scratch or gouge or depression caused by the bearing moving on the shaft.
