I can't get my stablizer arm in
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
gekko668
I took my strut out to check if the strut bearing is bad but when I bolt the strut back into the car's body the stabilizer bar is longer. How do i put it back in. I'm stump.
blindsnyper
Car: 2007 versa
I'm assuming that one side of the suspension is compressed, both sides have to be drooped. Or just use brute force :)
Francesco
You may have to place an extra jack under the ball joint to push the strut up.
Frank 2009 Versa S sedan MT-6 with 47300 miles
gekko668
Thanks for the reply guys. After an hour of pulling my hair out, i finally figure it out. All you have to do is twist the strut to the right and lower the stablizer arm to the slot hole, push it in and slowly screw the bolt in with the wrench.
Return to “Versa Technical Discussions”
