dfddfd2 »
https://forums.nicoclub.com/dfddfd2-u136200.html
Sat Jul 19, 2014 9:04 am
The CEL blinks the first digit of the code slowly, then the second digit of the code rapidly. The 1 12 is code 12 which is the MAF sensor, and your lack of acceleration is a symptom of a bad MAF. Code 123 1234 is a 34 which is the knock sensor, and lack of acceleration is also a symptom of a bad knock sensor. The final 12345, I don't understand, because if you ignore the initial 1, the first code would be 23, but that code isn't used.
