I can't figure out the CD changer
Supreme Wu
Car: 2006 Infiniti M35x
I read the manual about 10 times, follow the instructions to the letter, and I still can't load all six discs into the CD changer. I hold down load for over 1.5 seconds with the car on ACC and on the ON positions, and nothing happens (it doesn't give me the option to load all discs - in fact it only lets me load a single disc after I eject whatever is in there already).
There has to be some simple quirk that I'm missing. Did a search, found not much useful info.
retiredinaa
Car: 2006 M35X
Did you figure this one out yet. In case it's still an issue, you didn't mention choosing a numbered button after you indicate that you want to load a cd. Are you indicating which tray you want to load your cd into? If not, then you will just keep unloading and re-loading the same tray.
