I can't move my shifter from park position on my 2004 350
hope_someday
Car: 350Z
Can anyone help me. I can not move my car out of park on mine 2004 350Z
frapjap
'07 Subaru Legacy
Welcome to NICO!
Did you try pressing the brake pedal while you move the lever?
Also, check around the area to see if a button isn't being pressed that would normally be pressed while normally moving the brake pedal.
hope_someday
Car: 350Z
Thanks for the suggestion. I did try the above recommendation but no results.
frapjap
'07 Subaru Legacy
Jack up the car and look for the linkage that comes from the center of the car to the selector switch on the actual transmission case. If the G has one, it'll look like this:
or this
It may be located on the sides of the transmission or the top of the bell housing- I'm not too familiar with the G transmission.
sstroudwku
Car: 2013 F150 EcoBoost 4x4 - BlueJean Blue
2014 Pathfinder
More likely a failed shift lock solenoid. I've replaced 3 this year for customers. Pop the shift lock cap on the shift selector and push the button down inside it with a flap screw driver. If it'll move you at least can drive it til you can get the issue diagnosed.
alms24sebring
'04 Nissan Sentra SER SpecV
Thats a pretty detailed post. Remember there is also a relay in A/T shifter that allows you to shift from park when the brake is pressed. Listen for a clicking noise from the shifter when pressing the brake. Its usually the first thing to go when this happens.
But the short answer is, shoulda got the 6speed. :yesnod
Check brake switch first, then shift lock solenoid.
