I have to replace a busted timing chain on my 91 Saab 9000. This car is an automatic and its frontwheel drive.
I'm having a very very hard time with a similar board like NICO except its for Saabs, I don't get near the help there like I did here when I needed help with my 240sx. (under ther 240sx technical section obviously
Heres the problem. I have to get the crank pulley off. Which means removing the crank pulley bolt. Try to untighten the bolt makes the crank pulley turn.
Put the car in drive....crank pulley still turns. Is there some sort of trick to do this?
I done the timing chain in my 240sx but the chain wasn't busted. All I did to remove the crank pulley bolt was put the car in 5th, handbrake on and presto, off came the bolt.
Thanks in advance, I swear I'll get better help here for this german car than I will at saab forums.
