I bought some components, now what?
Post all your Nissan electronics, car audio and stereo questions here!
fiznat
Car: Grown up :(
I bought a set of components tonight: CDT CL-61a's from thezeb.com (check out the deal I got here: http://www.thezeb.com/caraudio....html)
Now, I know that I'm pretty much going to have to run an amp to power these speakers right. I'm hoping you guys could help point me in the right direction as to what brand/model I should go with, as well as things I should look out for when doing all this in general...
PS: Just so you know, I dont think I'm going to add a sub right away. I dont want it taking up space/weight, and I'm thinking the sound from these CDTs will be nice enough for me... Even still I want to be able to add a sub later on this amp in case I decide to... keep that in mind...
so watcha think I should get?
fiznat
Car: Grown up :(
oh in case you need them, here's the specs on the comps from the CDT website:
6.5" 2-Way Midrange: 6.5" Crossover: "Phase Perfect" Elliptic 4th order 2-Way SatNat-456 Tweeter: 1" silk soft dome Power Handling: 90 watt RMS Frequency Response: 60-20kHz Sensitivity: 92.0 dB Impedance: 4Ohm Surface & Flush mount tweeter
nolaws4evr
Car: cruisin tha streets of Huntsville, runnin down hondas, tryin to get money out of my insurance comp.
again Im going to point you in the direction of http://www.caraudioforum.com. Just post this thread over there under amps or whatever and you will get nothing but the best advise. They know stuff about audio half the people here wouldnt understand.
Josh
fiznat
Car: Grown up :(
hey man thanks for the address again.. heh I've been over there too: that's where I found out about this deal on the CBTs... Just asking over here as well to get a broader opinion.
nolaws4evr
maybe a jbl 600 will work good for you. I think you can get em for about 140-50 ebay style. check into the cadence z4000, or is it z?000, those are great for components and a sub. also hifonics older amps are awsome for larger multi channel systems. It really all depends how much you want to spend. Figure out your max $$$ you can blow and go from there.
Josh
