i bought a turbo kit for my ka
mechpro
Car: 1996 nissan 300zxtt 1984 vw scirocco 1991 240 sx
can i run it stock just add the turbo kit without a full fuel or ecu setup for just around town driving 7-8psi?
1mansho
No unless you want to blow your motor then yes.
480sx
Car: 1996 Pearl White 240sx
LOOK OUT MECHPROS IN THE HOUSE!
Run a 8:1 FMU with a 2-3 degree base timing retard from the dizzy. Done for 7-8 psi.
240sxka-t
Car: 94 sentra ga16 coupe
fuel cell? no. along with what 480sx said, you can get a walbro 255lph fuel pump for a safe upgrade. no ecu upgrade is needed unless you want bigger injectors
i have a walbro 255lph, rrfpr similar to fmu, stock injectors and maf and im running like 6-10psi daily. safe enough. how many miles on your motor?
mechpro
no miles comp;ete rebuild
480sx
Do exactly what i said to do and change your engine oil frequently for the first 150 miles.
EDIT - Try to keep out of boost as much as possible. Boosting on fresh rings sends excess blowby (unburnt fuel) into the crank case. Fuel in the oil is BAD. REALLY bad. There is nothing that destroys a motor quite as badly as excess(over 2%) fuel in the oil. If your oil smells like fuel, change it.
Modified by 480sx at 3:48 PM 6/29/2009
mechpro
so if i buy a fuel management unit and run it with my stock injectors and mass.air flow it will be just fine? looking for 300hp max for now? with an ecu upgrade and injectors and maf what is the max hp i could hold down? ive got a t3/t4 hybrid turbo external wastgate what is optimum boost for thiis?
