s13sickboi »
https://forums.nicoclub.com/s13sickboi-u160433.html
Wed Nov 23, 2011 8:41 pm
Are all connections tight and clean? Did you put all the wires back correctly? those fusible links are held in the box by bolts. (some of them are i'm not sure about s14's) check those to see if there melted or deformed
What exactly happened? Were you holding up the starter in the bellhousing and all the sudden get sparks? Better hope you didn't screw up your alternator or ecu!
