LongBeachCoupe »
https://forums.nicoclub.com/longbeachcoupe-u74279.html
Thu Feb 14, 2013 6:43 am
Tyler, isnt it backwards of what you said?
If it is made for a 2.5 it will be expecting to hold the weight of a QR, but when you put the VQ which weighs significantly more on the front end, I would expect that weight to compress the spring MORE not less, leaving the car sitting LOWER... I will ask one of the other staffers to chime in.
Regardless of if it will work or not, I would not do it, I have had a spring snap and it is a pain to have to deal with... Also the installation (of you are not doing it yourself, which I presume you are not or you would have realized the 2.5/3.5) is quite expensive... To have to do it more than once because you made a mistake is just not worth it IMO.
