I am rebuildin my ka24de
adam_91240sx
Car: 1991 240sx le hatchback
i am in a delema. i got layed off an have enoph to get one part. an i nead head bolts and a oil pump. but my oil pump is good but reduing my barings an piston rings. what should i get. sorry for my spelling. is the oil pump still good to use. please help.....
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
if it was working before you took it out you should be ok.
muscleinc1320
Car: 1991 nissan 240sx along with many others
i dont think that you can even change the oil pump sense it is built into the timing cover.
zachattack_5491
Car: Pignose S13 Redtop SR
muscleinc1320 wrote:i dont think that you can even change the oil pump sense it is built into the timing cover.
lolwut?? Yes you can change the oil pump.
Get what you need more. An oil pump is pretty important, but if it worked before it should still have some life. Get the head studs, put the motor together, and get a new oil pump when you get a chance.
adam_91240sx
ok thank ya for the help an ya it worked good an i hand scrubed the whole car with degreaser an painted an put piston rings main an rod barrings, rear main seal an crank seals an sent head th shop an honed block wish i could have honed block
NISSAN240SX12
1991 Toyota Supra
you could have honed it out yourself the tool cost like 15-20 bucks at Harbor frieght tools. sounds like you are doing great with the rebuild though
muscleinc1320
every time i looked for a new oil pump for my 240sx i could not find it.
zachattack_5491
muscleinc1320 wrote:every time i looked for a new oil pump for my 240sx i could not find it.
Sorry, I was wrong actually. You can't BUY an oil pump. But you can buy the rebuild kit for it through Nissan or I think AMS performance has one.
