I am not sure what was wrong
tenball
Car: Nissan 86.5 d21 auto trans hardbody .One mean machine
My truck was running like crap.So I read the codes "raised the hood ,saw that my idle was crazy so I unstuck the thermo element .Replaced the air flow meter.Still had a crank sensor code so I replaced the distributor.Truck runs great but stll has crank signal code 21.?????? I have 2 sets of plugs for each cylinder does it matter if the coil wires are reversed?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
It will matter if they are reversed. Have you check the FSM for proper routing?
http://www.nicoclub.com/FSM/Hardbody/d21_truck_1989.pdf
1989 still ran the twin plug Z24 engines so the information in the link I posted should still be valid.
