1+2= Nissan has huge after market support and you can get parts locally or on the net but
http://300zxclub.com has a ton of info there and a great classified adds forum thats a great place to score parts.3= best bang for the buck is twin turbo hands down but you can spend thousands and months collecting all the goodies and making all the mods to convert an NA to TT, but the best way is to remote mount the turbo's out back it has many advantages over conventional under hood installation the biggest benefit is removing the source of all the heat that kills the engine prematurely the engine doesn't know or care where all that heavily compressed intake charge is coming from. the 2nd benefit is you don't have to piss around changing the AC compressor PS pump rad mounts and rad etc. etc etc. Just rebuild your NA to TT specs they are essentially the same motor except for a few heavier duty parts and better flowing heads low compression pistons you should use TT pistons with wrist pins and oil pump and heads. I have a detailed build description with links and procedure I am currently working on packaging it as a kit and offering several different power levels and options.4= why would you ever want to do a skyline swap when the VG is as good if not better especially in a 300
