I am new.
tangywaffle
Car: 2010 Infiniti G37xS
2008 Infiniti EX35
1997 Infiniti Q45t
I have recently acquired a 1997 Q45t. i want to improve the suspension. any suggestions?
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
NyRider
Car: 1997 Infiniti Q45
WELCOME !!! yes...more and more fy33 owners clocking in
NyRider
first of all(1.) Is dinero (cash/price) going to be a problem - whatcha wanna spend... what it take's or what cha got
(2.) Are you willing to give up your (A)ctive suspension option
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
1.) $1000 would be as much as i could probably dish out.
2.) I didn't know i had "active suspension"
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
tangywaffle wrote:2.) I didn't know i had "active suspension"
You don't, but welcome to NICO anyway.
If you only have $1K and do all thework yourself, you can replace with OEM struts, shocks and worn rubber parts, including strut bearings in front.
Welcome to NICO
Wish I were new rather than old.
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
so a grand won't cut i for upgraded suspension? and i thought my audi was expensive to mod...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You can get the KYB SR Specials from member OneTonGarage and a set of Tein from FalkDesigns, or Espelirs, or if you don't want to scrape driveways and speed bumps, the out of production Eibachs.
tangywaffle
2008 Infiniti EX35
1997 Infiniti Q45t
thanks!
NyRider
Dang... all this time I beliveved the Q45T <-- meant active suspension am I wrong or was this only an option on later models like 98+
NyRider
hey you can get in touch with member q-project he is selling his whole setup which is fairly new for about $800 shipped that should take care of your suspension
Chrisfrend
In addition to replacing worn parts, there is one inexpensive mod that will significantly improve handling: replace the rear touring stabilizer bar with the much thicker bar from the standard 97 model. The result is much less see-sawing and much better body control in general. The touring rear stabilizer bar is much less stiff than the standard model bar.
The standard rear stabilizer bar and associated bushings are about $120 from Scottsdale Infiniti.
Thats a gorgeous car.
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
just clamp them coil springs together and weld a coil together for about a 1-1.25" drop. I did it on my BMW 540i. Weld with good amperage in spots for 180* so the spring is compressed evenly and you don't take the temper out of the spring.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
NyRider wrote:Dang... all this time I beliveved the Q45T <-- meant active suspension am I wrong or was this only an option on later models like 98+
Electronically adjustable shocks were standard on t model 1999-2001 and 2000 aniversary edition.
