LittleBrotherSilvia »
https://forums.nicoclub.com/littlebrothersilvia-u10177.html
Wed Aug 13, 2003 8:30 pm
seeing as how i just painted my S14 i figured i'd add my 2 cents, first u dont need to sand all the way through the original clear coat, unless it is chipping/scratched all the way through/etc., just scuff the surface really well and get all of the "shine" off, next do a coat of primer on the entire car, whoever said u dont need primer is full of ****, then sand the primer smooth with 400 once it is dry and has set well, spray some more primer if u sand through anywhere, then sand those spots smooth, then u'll want to do what someone said and spray light coats of base color, then the clear, do a coat or two of clear, wait for it to set well, then sand any bumps runs or bubbles with 400, BE VERY CAREFUL NOT TO GO THROUGH THE CLEAR, then spray another light coat of the clear and u should be pretty good to go.
i hope this helps
