DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Dec 02, 2002 1:46 pm
There is some labor overlap, and now would be a good time, but it is probably a healthy amount of additional work and cost. The guides are behind the front engine cover, so the belts and pulley have to come off as well. The chains are probably good for 250k, so replacing them depends on miles on your car and how much you drive. If you're doing the guides and covers, it's probably a no-brainer to have the chains done unless you have very few miles on the car. These items have to come off to do the chains, so if you're going to keep the car for a while, bite the bullet now and pay for the parts. If the rattle is indeed coming from the covers, it's likely not the guides or chains, but it needs to be looked at. Resealing the covers gives a great opportunity to do so. Not sure about the oil pressure switch. If it wasn't working, you would probably get a red oil light on the dash. Probably just needs to be replaced, and the part and labor shouldn't be too much.
