Inabj2 »
https://forums.nicoclub.com/inabj2-u6052.html
Fri Mar 28, 2003 2:06 pm
Update, I talked to the seller dealership, and well thier law is on ther side, I cannot return the car until the 4th time I come in with claims. MD law can kiss my ***.
So it left me one option, on monday, they will send a tow truck to pick up my car and take it into their dealership. And free of charge repair the things stipulated in the original ticket, (spark plugs, fuel pressure regulator.)
However that is the things that it needs to even properly check the car properly.
After they do this, I will send the car and run another diagnostic check once again. Talking with the other mechanic that ran the check, looks like my initial suspincions of the timing chain might be right.. Also from speaking with the other mechanic, looks like the previous owner messed with that engine and ran the poor 240sx hard. At this points they are suspicions.
Well, Ill let them fix the original problems. Once I pick it up, Ill have my brother whom is a mechanic, take a look at it. Run a compresion test, then return it to the local nissan shop and run another diagnostic check.
