Kansei240sx wrote:Ok, so i recently took over an RB20 project and took the wiring harness, upper and lower, and entirely went over them and repaired numerous melted/damaged wires in the harness and even replaced some that were missing. Its all perfect the way the FSM specifies but i cant ****in figure out where the wires go to this last plug.
To elaborate if the drawing isnt simple enough, there is this plug that goes directly into ( See picture below )
Btw, the black wire with red stripe looks like it has been repaired because just before it goes into the connector its blue.
This is the last damn connector and this car will run!!!
Thanks for any correct information, i hope carl chimes in!
Modified by Kansei240sx at 6:31 PM 7/2/2008
That is the connector that supplies power to the coils. The blue wire in your diagram gets grounded. (IMO if you can ground it directly to the battery, otherwise a good chassis ground).
The wire with the 2.2k resistor I forget what that one is off the top of my head. I'll have to get back to you on that one.
