i allready searched( how do i disasemble my s13 door)
dori240
Car: 2000 ford focus, 92 nissian 240sx
so i have a ****ty passanger door and i got a new one. the newone is manual and has tinted glass and i wanna put the power switch and normal glass on the new shell. i got most of it dissasembled and un wired but now im sorta blank
Modified by dori240 at 1:56 PM 8/12/2005
corn322
Car: 1993 240sx
just put it together the way it came apart.
dori240
i'm not shure how to get the whole power and manuale assembly out
gumby
Car: '89 240sx sohc
all bolts and screws get removed.
the trim unsnaps
i just did this it was simple even though it took 3 hours
dori240
OMG eaither i'm a retard for not explaning it properly or you guys are retards for not understanding.....i'll post a pic tommarow
dori240
new door
Old door
hears an example of what i dont know how to remove
gumby
Car: '89 240sx sohc
just start doing it and youll figure it out.
dori240
i know thats whats gonna end up happening
onosqv
Car: '92 240sx Vert
Haha.
First off, get 2 people at least. I remember when I had to completely take out the auto door to replace the motor assembly. Keep in mind this was about 2 years ago.
Anyway, I believe there are approx 2/3 bolts on top & 2/3 bolts on bottom holding the glass in. You have to reallly look in there.
Get the glass out first, then the rest will come out pretty easy.
Easiest way to see how it all works is to remove all the crap from your good door so you can see how the motor moves the glass up & down and what positions you need to get to.
You will have to use all those crazy holes in the door to get to the bolts & such.
Sorry I wasn't much help, but it's "not that hard." Took me & my uncle about 1 hour or so. It's really just a few bolts .
dori240
thanks
tyrannix
Car: go big or go home
right under the 'ledge' of teh window, there are 2 stoppers that prevent the glass from coming out , lower the glass and take them out
then take out the 4 bolts that hold teh glass on the brackets (2 on each side)
now you can just slide the glass out the top (and put it somewhere soft and flat.... having to get new glass sucks)
next theres just 4 nuts holding in the regulator (the whole automatic assembly, its 1 unit... the only thing to disassemble on it is the motor comes off) just remove those nuts, unplug the harness and pop it back, it will slide out the top
really, if the whole process takes more than 1/2 hour stop, get a drink, and come back to it
when reassembling, look at the bottom holes where the regulator bolts in, they are slotted so you can make adjustments...
after you get the glass back on, and the stoppers on, close teh door and roll it up.... make sure it has a good seal ...
next open the door, see if its up all teh way.... if not, roll up then close doorsee if it closes, and has a good seal (not my s13, but another car i had i didnt do all of this, and ended up having to take the door apart again to make it fit correctly
