OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Fri Jul 24, 2009 2:59 pm
Depends.... He was taking about a 4-6 inch core radiator, a 3 inch radiator is a different animal, but you are correct, solid airflow is key, pressure is key, and so is the proper flow rate. Too fast and it wont allow the water enough time to cool, too slow and they can heat soak.
My heat soak issue is that of venting. I may prop the rear of the hoof a little, but I hate the ascetics of it.
I expect a good water temp drop with this set up. Its about 15% more surface area, and it vents into a area where heat is trapped. I need to wrap my headers still,wrap the intake, vent the bay, and add the oil cooler.
I think when you get your running, you may have to do something to disburse the heat too,
