I-35 /w sport 2003 17'S or 18'S
hsosa
Car : i-35 W/SPORT PACKAGE 2003
Basically looking for looks and improved performance mainly freeway driving / no racing or insane driving.
Ive been trying to find a site forI-35 but I guess this car is not very popular.tried to do research on tires and wheel combinations
Tiretrack is a great price.
Here is my dilemma /// we got the sport package this give us Vehicle dynamic control / we also have traction control on this car.
I want to get 18's but Im afraid that the 18' wheels will throw off the computers that sense VDC and traction control. Does anyone know out there if this is the case or will the computers adjust for the larger wheels? This is a front wheel car V6 3.5 same engine for the maxima and I think altima as well..
I also have the sport tuned suspension/ basically stiffer shocks
Thanks for the time
Exar-Kun
Car: 2005 350Z
as long as the O.D. remians withing + or - 3% or so you wotn affect the VDC or speedo, abs, etc. ALso, search around we discussed the load index issue a while back on upgrading wheels and tires on a vehicle.-chet
hsosa
So I can go OD 45's and 18's that s what I would probaly do. right now I have OD 50's /
Exar-Kun
Car: 2005 350Z
dude OD=overall diameter, I dont know what you think it means.
if you have 225-50-17 on the car now, you can run a 225-45-18 and it'll be just about perfect.-chet
hsosa
Yeah sorry meant 215/45/18 //
Great should be good on these wheel and tire combination/
what tire would you recommend? Mostly freeway driving live out in southern california
Exar-Kun
Car: 2005 350Z
225-45-18 should be nearly the same OD and keep loading similar, not sure about 215-45, that would be too short(I am assuming your car has 225-50-17 on there now, like maximas do).
I would check into the bridgestone s-03's. call up grant, they run about 200 a peice in that size.
if you want to get away cheap:http://www.tirerack.com/tires/...1=yes
check those out, not great overall, but they're cheaper than anything else in that size.-chet
hsosa
my bad right 225/45/18 those would be the correct one.
Do you guys have credit plans? ALso when I order wheels and tires do they come balance or is that something that I need to take to a garge?
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Hi,Grant here. That 225/45-18 keeps you right on the money for the O.D. When you order the tires and wheels at the same time they come mounted and balanced at no extra charge. They come ready to bolt on the car. Most folks do it at home in the garage. We don't offer credit plans but you can use any major credit card or Western Union Quick Collect. If you do order from Tire Rack, be sure to use the link of the forum or contact us directly at 1-877-522-8473 ext# 313. That way the forum gets credit for the refrence. That helps support our forum here:pface
hsosa
Great thanks. As soon as I decide I'll give you guys a call. My main concern is that the 18's wont throw off my traction and VDC controls on the car
PalmerWMD
Car: 2004 350Z
HS:They wont if the tire diameter stays the same and it does.
Fred..:)
