i30atl80 »
https://forums.nicoclub.com/i30atl80-u46278.html
Tue Aug 11, 2009 9:54 am
I have a 2000 I-30 with about 125K miles. Recently I have been having an issue with the engine fluttering at very low idle and then shutting off while the car is in park. If the car is stopped, but in gear, it might flutter a bit but does not shut off...it's only when the car is in park.
Also, first thing in the morning, the car hesitates several times when I am first starting off to work--like I press the gas and the it doesn't really want to go. After a minute or two, the car runs fine with no hesitation. It only happens after the car has set overnight. If I were to go start it up right now, it would be fine.
I'm not sure if these two things are related or not. In the past year, I have changed all O2 sensors, all six engine coils and spark plugs. I got all of the parts from the dealer, so I am sure that it should not be any issue with the quality of the parts or a fault of aftermarket parts.
Any thoughts?
Thanks in advance.
