evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Aug 16, 2008 7:17 am
lol, well the strut sectioning works on the S13 as wel, you get lowered ried height with increased travel, you can go lower without wearing out your struts ,I bought a kit form Ground Control and weld in camber plates form Techno Toy Tuning, the weld in camber plates are of course optional, there are bolt in available as well but both require cutting out your strut towere, something not everyone is comfortable with, the MSA and EMI uppers are a bolt in camber correcting hat intended for use with coil overs, the GC kit is just sleeves, stops, collars, springs and hats
and if I were you I'd put the higher spring rate up front and the lower int he rear, stiffer rear end will lead to uncontrollable oversteer, all the weight is up front so the stiffer it is the less roll you'll have, the rear needs a bit of compliance to allow it to move enough to maintain grip
