StryfeS13 »
https://forums.nicoclub.com/stryfes13-u150110.html
Sun Dec 20, 2009 2:07 pm
So, call me an idiot. But I got bored and was going to try to clean my fuel injectors.
So I relieved the fuel pressure (loosen gas cap, take fuel pump fuse out, turn car on let engine die, etc.) ,removed the harness from the injectors,and then took out my injector on piston #2, just to get a feel for it. Then I cleaned the tip of it, and placed it back in, the o-ring was fine. So, I go to crank it over and it wont start. I already knew what had happened, so, I took out my #2 spark plug, look down the hole and sure enough, there was gas in there. So, I removed all plugs and cranked my engine over until all the gas shot out. But when I turn my key to "on" position, the fuel pump just pumps gas right back into cylinder #2. Oh, and something else that is weird is that when I pump all the gas out (with the fuel pump fuse out) it will start after and run without the fuel pump fuse in...meaning the fuel pump isn't on but the car stays on.
Can anyone explain why this is happening and how I can go about fixing it?
I need to stop trying to fix things that aren't broke haha.
