SmoothCriminal »
https://forums.nicoclub.com/smoothcriminal-u12016.html
Fri Jan 02, 2004 1:29 pm
I've already examined the motor with the damaged guides and valves. The bottom-end looks to be in good shape and the engine turns fine but the headwork is absolutely wrecked, it looks as though some of the valves are practically embedded into the cylinder-head, some are badly bent. Obviously the chain's snapped as well. I'm just worried that a hydro'd motor would have the same (catastrophic) symptoms ie bent valves, bottom-end but the mileage is much less. I'll probably just try to salvage what I can - cams, cs & other sensors, ignition coils and ignitors and turbine sensor, transmission.
I've already started freshening up the bottom end. Pulled off the oil pan and cleaned it with industrial strength solvents. The one bright spot (no pun intended) is that the owner used synth and changed it at regular intervals because it looks spotless for a car this age. Scrubbed out the plenum with some shop towels and liberal amounts of industrial strenght car cleaner spray. The transmission on the other hyrdo'd engine will be sent in for rebuilding this week.
I've got a tip on another Q motor in the area that I'll scope out on Monday. At the least I'll pull of the heads as I was told the car was a snow victim, motor runs fine. I must say though, I crater to the "street rod" and "import tweaker" crowd but this engine is a damn fine specimen of meticulous engineering (besides the cg faux pas). It's a damn shame to see these metal behemoths succumb to owner negligence. Anyway I'm looking forward to rescuing this one from the crusher and commissioning her for use as a damn fine family car.
