romerider153 wrote:luner i would love to see some picks on how you did this and by doing this would i still not need the e brake assembly can this be used as a short term e brake will in park as long as you have a way to hold the lever up thanks
You got it! Sorry it took me so long but work was hell these past two weeks
Excuse the bad picture quality, and photo size I'm hung over and just dug up old photos. this is the route I went while using hard bendable hydraulic lines and a CNC staging brake. The only issue I ran into was the hard lines themselves which I found hard and annoying to route into the car, I eventually went with stainless steel braided lines routed in through the driver side fender well hole and made a shorter circuit of hydraulic cabling.
Hard lines are easily done and require some minor effort in routing them in, where as making your own lines VIA summit stainless steel hosing and fittings was quick, faster to bleed, and overall cleaner apperence in the car itself.
^This is the Business end of the CNC Staging
^side view of Line in and Line out
^god have Mercy I Actually routed hard line through all that in the fender well and drove around line this
^The yellow dot is the OEM coupling that the line from the staging brake goes into.
^Overall engine bay shot of the line to the Master cylinder *note that the new line is silver.
^BMC *note that the new line is silver.
And there ya go!
Any Questions?
