beautifulmys »
https://forums.nicoclub.com/beautifulmys-u181913.html
Thu Mar 31, 2011 10:56 am
About a week ago, I managed to hydro-lock my 2005 Nissan Sentra. I went through a flooded street and about 2/3 into the puddle, my car hydro-locked. I towed it to the mechanics the next morning (it happened at night) and sure enough, there was water in my engine. After the mechanic took off the spark plugs, and pushed the water out, the engine started right up. There is a little bit of a problem with the engine, the ignition will climb almost to 2000 rpm and then drop back down to 1000 rpm. I am taking it back to the mechanic today to see if maybe it needs a tune up. I don't think I bent a rod or anything, because there is no knocking or other suspicious sounds in the engine. I will see after today though.
