Darius »
https://forums.nicoclub.com/darius-u5470.html
Mon Aug 25, 2008 8:43 am
First, push down on each lifter with your thumb and see if it moves more than a millimeter or two. If it does, then the lifter should be disassembled and cleaned to ensure that the ball check valve inside isn't just stuck and malfunctioning. Yes you'll have to remove the cam(s) for this.
Ok assuming that there's new valves in there and it has a "tick", you need to check the lash with a feeler gauge. If you can slide the thinnest gauge between the cam and lifter, it is most likely going to tick.
The gap could be due to a valve stem being too short or the seat not being cut to match the valve. Numerous reasons, but dead lifter is fairly unlikely.
