pgt892 »
https://forums.nicoclub.com/pgt892-u2513.html
Sun Jun 19, 2005 11:19 am
If you have the S14 SR FSM turn to page EM-46 and it will tell you how to bleed the HLAs. "Remove hydraulic lash adjuster and dip in a container filled with engine oil. While pushing plunger as shown in figure, lightly push check ball using a thin rod. Air is completely bled when plunger no longer moves. Air cannot be bled from this type of lash adjuster by running the engine."
