compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Wed Apr 04, 2012 9:10 am
There is no need for a check valve because the hand brake will only ”force” fluid one direction. If your that worried about it they do make 1 and 2 psi check valves. You wouldn't want a full one way check valve because once the brakes were pressed.... The rear brakes would stay fully locked. The hydro ebrake will not effect your normal brakes when not activated so you can install a brake bias before or after .... Doesnt matter. Imo a bias will not help you're brakes that much because the proprtioning is all done in the master cylinder on most nissans. Easiest way to run your hydro is disconnect the rear line where it connects into the T for the rears, run that to your hydro inlet and then buy a new line and run it from your hydro outlet to the rear T for the rears. As far as brand..... No idea. I know that wilwood makes the best hydro master cylinders for handbrakes..... Other than that, its personal preference on the handle setup.
