prizzom »
https://forums.nicoclub.com/prizzom-u63550.html
Fri Nov 21, 2008 1:28 pm
Okay i read on the other forum post and tried what other people said but none of it helped.
This is my problem, when i push the clutch pedal down it wont come back up. There is no feeling in my pedal at all. So far i brought it to the lift and we check the slave, it was good there was no leak or fluids. So i bought a new Master, thinking it must have just been that. I installed the new master and adjusted the shaft thing on the master so that the pedal moves from the top switch (cruise) and to the bottom switch (ignition) fine. We went to go bleed the lines, first we bleed the one by the box, i think its called the booster line, then we bleed the slave. We bleed it with a vacuum sucker thing and there were a bunch of bubbles coming out and the bubbles wouldn't stop coming out. So we tried the old method of pressing the pedal down three times (pulling it all the way up then pushing it all the way down), and then held it down and loosen the bleeding screw. we didnt have any bubbles comes out when we did that method. But the hydaulic system still isnt working. What could be the problem?
Thanks
