hydraulic clutch line
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
lil89ram50
Car: 1985 nissan 720 1989 dodge d50 1979 chevy luv
hey guys my clutch line sprung a hole today! so now im w/o a vehicle! do they make these still? i need the one that goes from the clutch to that little box on the firewall. ald also, how do i go to bled the system? i saw a bleeder screw on that box on the firewall... is that the only one? and do i just bleed it like brakes and pump it up then open the valve and repeat till good and stiff? and would the local parts store or a napa be able to get me one, or woulld i have to make it?
thanks in advance!
seang
Car: Ford Fiesta ST
IDK where to get a line because I don't even own a 720. The little box on the firewall is the clutch damper, and you can bleed it just like you would brakes. There is also a bleeder on the clutch slave cylinder to bleed as well.
lil89ram50
seang wrote:IDK where to get a line because I don't even own a 720. The little box on the firewall is the clutch damper, and you can bleed it just like you would brakes. There is also a bleeder on the clutch slave cylinder to bleed as well.
so where do i do the bleeding from? the damper or the slave cylinder?
seang
Car: Ford Fiesta ST
Do both, starting with the one closest to the master cylinder.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
you need to bleed both. the clutch does not get hard like the brakes. Bleed until no air is seen coming out.
Return to “Datsun 720”
