Mayhem_J30 »
https://forums.nicoclub.com/mayhem-j30-u111.html
Fri Feb 14, 2003 5:00 am
If the cam maker suggest different springs with different forces then yes get the new springs. If not you can have the springs tested to see if they are still withing factory spec, if not replace them. Keep ya from getting the ticks that are sometimes associated with more aggresive cams. If I was going in I would replace all lifters and springs, just because that's the way I am. Courtesy Nissan recently has put the VG30De lifters on sale for 1/3 the normal cost which would save MAD cash considering the VG has 24!Anyway, it's important that your springs match with exactly what the cam manufacturer (regrinder) has spec'd out. otherwise premature lifter wear and slap could occur.
