hybrid turbo......any guesses regarding output?
mbmbmb23
I have an S14 compressor and wheel......and a CA T25 turbo.........if I put the S14 compressor parts with the CA T25 center and hot side......what could I expect for spool and HP output?.....and at what point would the hot side be choked?
thanks,
-M
float_6969
AFAIK nobody's done that before. That makes for a pretty unbalanced turbo though. It certainly can't hurt to try though!
Zero260
Car: 91 240sx coupe
I don't know what size the s14 stuff is, but if it's to large to run with a ca T25 houseing and Turbine wheel, you'll end up getting compressor surge. whihc will destroy your Turbo pretty quick.
mbmbmb23
Zero260 wrote:I don't know what size the s14 stuff is, but if it's to large to run with a ca T25 houseing and Turbine wheel, you'll end up getting compressor surge. whihc will destroy your Turbo pretty quick.
I'm running a BOV so compressor surge shouldnt be an issue.
Nowhere
Car: Suzuki x-90, samurai
Throttle plate closing surge and turbo running surge are two different things..
Neither are good though..
mbmbmb23
Nowhere wrote:Throttle plate closing surge and turbo running surge are two different things..
Turbo running surge is reduced by using a wastegate....no? If not, then please explain.
thanks,
-M
