Ok, so I used the 240 housing (saved me a lot of work because I didn't have to deal with the pinion), with the 240 ring gear and bearing spacers. I used the q45 center section, bearings and races. Backlash feals identical to how it was before but I'll double check later with a gauge. My question is, notice the right shaft sticks out further than it should. The seal still seals the shaft but is definately further out. I've heard of people cutting the shaft shorter but I don't understand how that would even make a difference because the snap ring in the vlsd controls output shaft depth and once it snaps into place, that's how far it goes in..... So????
